Adjusting the Backlight Brightness
Extensive use of screen backlighting can significantly reduce battery life. You can adjust the backlight brightness to maximize the battery life.
NOTE: The backlight brightness may be limited when the battery is low.
  1. Select Power.
  2. Use the slider bar to adjust the backlight brightness.
The device may feel warm when the backlight setting is high.
Copyright © Garmin. All rights reserved.GUID-9B02DCC5-9EBB-4B8A-A2A8-3E75FDC66D07 v1
