Editing Location Alerts
  1. Select Location Alerts.
  2. Select an alert.
  3. Select an option:
    • Select Disable to turn off notifications for this alert.
    • Select Set Alert Type to set the way the device notifies you for this alert.
    • Select Set Alert Mode to set the notification to sound on exit, entrance, or both.
    • Select View Map to view a geofence on the map.
      NOTE: This feature is not available for the radius alert type.
    • Select Delete to remove the alert.
Copyright © Garmin. All rights reserved.GUID-9B02DCC5-9EBB-4B8A-A2A8-3E75FDC66D07 v1
