Turning On and Off the Transmitter
Before you can add a contact or initiate an emergency alert, you must ensure the transmitter is enabled.
NOTE: In cold temperatures, if you transmit when the battery is low, the device may shut down.
  1. Press Power to open the status page.
  2. Select My ID > Transmitting.
Copyright © Garmin. All rights reserved.GUID-9B02DCC5-9EBB-4B8A-A2A8-3E75FDC66D07 v1
