Removing the Old Battery
Before you replace the battery, you must remove all dirt, water, and debris from the device. You must also have a small Phillips screwdriver.
  1. Remove the six screws from the outer edges of the back plate.
    NOTE: You should leave the two inner screws in place.
  2. Pry off the back plate.
  3. Disconnect the battery connector and power connector.
  4. Remove the screws that secure the battery cover.
  5. Remove the battery cover and the battery.
    Remember the orientation of the battery. You must install the new battery the same way.
After you remove the old battery, contact your local waste disposal department to properly recycle the battery.
Copyright © Garmin. All rights reserved.GUID-9B02DCC5-9EBB-4B8A-A2A8-3E75FDC66D07 v1
