Position Format Settings
NOTE: You should not change the position format or the map datum coordinate system unless you are using a map or chart that specifies a different position format.
Select Setup > System > Units > Position Format.
Position Format
Sets the position format in which a location reading appears.
Map Datum
Sets the coordinate system on which the map is structured.
Map Spheroid
Shows the coordinate system the device is using. The default coordinate system is WGS 84.
Copyright © Garmin. All rights reserved.GUID-9B02DCC5-9EBB-4B8A-A2A8-3E75FDC66D07 v1
