Customizing the Main Menu
  1. From the main menu, select Setup > Main Menu.
  2. Select an option:
    • To move a menu item, select a menu item, and select a new location.
    • To delete a menu item from the list, select a menu item, and select Remove.
    • To add a new menu item to the list, or to place an item on the list after you have removed it, select Add Item Here.
    • To reset the order of all items in the menu, select Menu > Restore Defaults.
Copyright © Garmin. All rights reserved.GUID-9B02DCC5-9EBB-4B8A-A2A8-3E75FDC66D07 v1
