Recording Track Logs
By default, the device automatically starts recording your path as a track when it is turned on and has acquired satellite signals. You can pause and start recording manually.
  1. Select Track Manager > My Track.
  2. Select an option:
    • To control the current track recording, select the current track tab.
    • To view data fields for the track, select the information tab.
    • To view the current track on the map, select the map tab.
    • To view the elevation plot for the current track, select the elevation plot tab.
Copyright © Garmin. All rights reserved.GUID-9B02DCC5-9EBB-4B8A-A2A8-3E75FDC66D07 v1
