Changing the Role of an MOB Tag
NOTE: At least one MOB tag with the Captain role assigned must be paired for the Garmin OnBoard™ engine cutoff system to function. You cannot change the role of a Captain tag if it is the only tag paired with the Captain role assigned.
  1. On a connected chartplotter, select Settings menu > Communications > Wireless Devices > OnBoard MOB System > MOB Tags.
  2. Select the MOB tag you want to change.
  3. Select Role.
  4. Select the role you want to assign to the MOB tag.
September 2026
