Spy Pole Control Bar
The Spy Pole™ control bar allows you to control Spy Pole™ mounts connected to the chartplotter.
You can select an item to engage or disengage it. The button illuminates when it is engaged.
The name of the connected Spy Pole™ mount associated with the control bar. If you have more than one Spy Pole™ mount connected to the Garmin BlueNet™ or Garmin® Marine Network, select this to choose a different device to control. |
Status of the Spy Pole™ mount. |
Select to engage SpyLink™ synchronization. You can use this feature only when the Spy Pole™ mount is connected to a compatible Garmin trolling motor (SpyLink Synchronization). |
Select to engage automatic SpyLock™ point locking ( SpyLock Feature). |
Select to engage SpyScan™ search mode (SpyScan Search Mode). |
Select to engage OneVü™ sonar 360-degree scanning. You can use this feature only after you connect a compatible 360-degree sonar transducer, such as a Garmin GT360UHD, to the end of the Spy Pole™ mount, and assign it to that Spy Pole™ mount (OneVü Scanning Sonar). |
Select to turn the Spy Pole™ mount to the left or right in step increments. |
Select to open options and settings for the Spy Pole™ mount (Spy Pole Options and Settings). |
