Attaching the Band or Carabiner Loop
The MOB tag is packaged with a carabiner loop, a wristband, and a floating keytag. You can use the carabiner loop to attach the MOB tag to your clothing, or you can attach the MOB tag to the wristband to wear it on your wrist. You can also attach the floating keytag to the carabiner or to the wristband to prevent the MOB tag from sinking if it is accidentally lost in the water. Follow these steps to attach the wristband or the carabiner loop to the MOB tag.
  1. Insert one end of the spring bar on the band or carabiner loop into one of the holes on the MOB tag.
  2. Slide the quick-release pin to retract the other end of the spring pin.
    Installing the wrist band
  3. Align the spring bar with the other hole in the MOB tag, and release the pin.
September 2026
