Configuring Digital Switches for Voice Control
Before you can use the voice control feature on the chartplotter to control switched devices using your Garmin Boat Switch™ device, you must assign details about the devices connected to each switch you want to control.
  1. From a Garmin® chartplotter connected to the same NMEA 2000® network as the Garmin Boat Switch device, select Settings menu > My Vessel > Switching > Voice Control.
  2. Select the switched channel you want to configure for voice control, then select Select Type.
  3. Select the type of device connected to the switched channel, then select Set Type.
  4. If needed, perform any additional configurations for the channel and device:
    • If you have more than one type of device on the boat and you need to add an identifying number (ex. light 1, light 2, etc.), select Select Identity, select a number to assign to the device, then select Set Identity.
    • If you want to see examples of how you can use voice control for the device, select Show Examples.
    • If you made mistakes and want to reset the voice control settings for the device, select Reset.
After you have set the type and optional identity information for devices connected to the Garmin Boat Switch device, you can use voice control to interact with them (Chartplotter Voice Commands).
Device Types For Voice Control
Because the Garmin Boat Switch device is preconfigured for specific device types on certain channels, you can refer to this table to help verify that you are assigning the appropriate details to each channel you want to use with voice control.
Channel1
Device Types
1
  • Red/green navigation light grouping
  • Red/green/white light grouping
  • Generic latching device
2
  • White/anchor navigation light grouping
  • Anchor light
  • Steaming light
3
  • Anchor light
4
5
9
10
11
Live well pump
12
Bilge pump
13
Bilge pump
17
Generic latching device (dimmable)
18
19
20
21
25
  • Horn
  • Generic momentary device
26
  • Horn
27
  • Horn
1
Not all channels on the Garmin Boat Switch device are valid for voice control
September 2026
