SpyLink Feature Requirements
Before you can use the SpyLink™ feature with the Spy Pole™ mount, you must perform specific configuration processes on the system.
  • You must install a compatible Force® trolling motor on the vessel and pair it with the Spy Pole™ mount (Pairing with a Force Trolling Motor).
  • You must update the Force trolling motor to the latest released software. See the owner's manual for your trolling motor for software-update instructions.
  • You must set the bow offset for the Spy Pole™ mount and for the trolling motor.
    TIP: For the best results, you should set the bow offset for both the Spy Pole™ mount and the Force trolling motor at the same time. This helps to ensure that the two devices are in alignment with one another.
September 2026
