Labeling a Switch
You can provide a custom label for each switch. The switch label is separate from the switch name.
  1. From a Garmin® chartplotter connected to the same NMEA 2000® network as the Garmin Boat Switch™ device, select Settings menu > My Vessel > Switching > NMEA Standard.
  2. Select the switch number.
  3. Select Label > Edit Label.
  4. Enter a new label.
  5. Select Done.
September 2026
