Garmin SideVü Sonar View
NOTE: Not all models provide built-in Garmin SideVü™ sonar support. If your model does not provide built-in SideVü sonar, you need a compatible sonar module and compatible SideVü transducer.
If your model does provide built-in SideVü sonar, you need a compatible SideVü transducer.
SideVü scanning sonar technology shows you a picture of what lies to the sides of the boat. You can use this as a search tool to find structures and fish.
SideVü sonar view with callouts
1
Port side of the boat
2
Starboard side of the boat
3
The transducer on your vessel
4
Logs
5
Old tires
6
Trees
7
Water between the vessel and the bottom
8
Distance from the side of the boat
September 2026
