Steer Assist
WARNING
You are responsible for the safe and prudent operation of your vessel. Steer assist is a feature that can provide information on steering your vessel. It does not control the helm for you or relieve you of the responsibility of safely operating your boat. Avoid navigational hazards and never leave the helm unattended.
Steer Assist is a set of sailing features provided to help you steer on the optimal course while sailing. You must select or import a polar table before you can use the Steer Assist feature ( Polar Tables).
NOTE: Steer Assist is enabled automatically when you select or load a polar table. To deactivate Steer Assist, select Settings menu > Preferences > Navigation > Steer Assist.
Sail assist feature with callouts
1
Navigation turn or destination:
  • The wide magenta line indicates the initial route line to the next turn or the destination.
  • The thin purple line from your vessel to the next turn or to the destination indicates your present bearing to the next turn or to the destination.
  • The port and starboard laylines are determined by the polar table you are using.
  • The bold dashed line (can be red, green, or purple) indicates the recommended Steer Assist bearing to follow.
2
Steer Assist data field:
  • The first number listed indicates how you should turn to align with the suggested optimal course for the present maneuver. A value of 0° indicates that you are on course.
  • The percentage indicates your present speed as compared to the ideal speed for the conditions. If the number is lower than 100%, you should consider adjusting the trim to increase your speed.
  • The triangle or triangles on the side also provide guidance based on the color and shading:
    • A red triangle or triangles indicate that you are aligned with the port layline.
    • A green triangle or triangles indicate that you are aligned with the starboard layline.
    • A magenta triangle or triangles indicate that you are aligned with the bearing to the next turn or destination.
    • A triangle with a white center indicates that you are within 3° of the optimal course and should maintain your heading.
    • A solid triangle or triangles indicate that you are off course by more than 3° and should adjust your heading.
September 2026
