Assigning a Shortcut to the Trolling Motor Remote Control Shortcut Keys
You can configure the numbered keys on the trolling motor remote control to quickly change to a screen on the chartplotter, such as a sonar or chart screen.
NOTE: If you have more than one chartplotter on your network, the shortcut keys on the trolling motor remote control work on only one chartplotter at a time. Shortcut key assignments saved on one chartplotter do not transfer to other chartplotters on the network.
  1. If you have more than one chartplotter on the network, open the Trolling Motor Bar bar on the chartplotter you want to control using the trolling motor shortcut keys, select Menu symbol, and turn on Shortcut Keys.
  2. Open the screen you want to save a shortcut to.
  3. Hold a numbered key on the remote control.
    The chartplotter shows a notification banner to confirm the key assignment.
The shortcut is also saved to the Pinned category on the chartplotter.
September 2026
