HDMI Out Video Considerations
NOTICE
To prevent corrosion due to moisture, you must use Garmin® accessory cables when connecting the chartplotter to the video display. Using different cables voids your warranty.
The ECHOMAP™ Ultra 2 16Xsv chartplotter models have HDMI® out capability to duplicate the chartplotter screen on another device, such as a television or monitor.
The Garmin HDMI accessory cable is 4.5 m (15 ft.) long. If you need a longer cable, you should use an active HDMI cable only. You need an HDMI coupler to connect the two HDMI cables.
You must make all cable connections in a dry environment.
Block diagram
Item
Description
1
ECHOMAP Ultra 2 16Xsv chartplotter
2
Garmin HDMI cable (HDMI)
3
Display with an HDMI In port, such as a monitor or television
4
Dry environment, protected from moisture
September 2026
