OneVü Sonar Appearance Settings
From the OneVü™ sonar view, select Menu options symbol > OneVu™ Setup > Appearance.
Color Scheme
Sets the colors used on the sonar view.
Range Rings
Shows and hides the rings on the sonar view indicating the sonar range.
LVS Beam Area
Shows and hides the beam area for the connected LiveScope™ transducer.
Spy Pole™ Direction Line
Shows and hides a line that indicates the direction the Spy Pole™ mount is facing.
NOTE: This setting is available only when a heading signal is detected.
Waypoints
Shows and hides any saved waypoints in range of the sonar view.
Orientation
(2D view only) Sets the orientation of the sonar view to show either your heading or north as up.
View Offset
(2D view only) Adjusts the overhead view to the front, back, or either side of the vessel.
September 2026
