WARNING
This device is intended only for recreational use on a racetrack. Never use this
device on public roadways. Failure to follow this warning may result in an
accident causing property damage, serious personal injury, or death. You are
responsible for using this device in a safe and prudent manner.
Before you can start a drag race session, your device must acquire satellite signals. You can
select
in the status bar to check the current signal strength and
accuracy.
From the home screen, select
Drag Race.
Select an option:
To change your driver profile, select .
To change your vehicle profile, select .
To configure lap timer settings, select
, and select Delta Timer or Lap Timer Display.
To change your track conditions, select Session Settings, and select Prepped Track if your track has been treated with chemicals, or
select Unprepped Track if your track has not been treated with
chemicals.
To enter your tire pressure, select , and enter your current tire pressure.
To enter the launch RPMs for your vehicle, select .
To change your audio configuration, select Session Settings, and select your audio connection.
To enable or disable audio or video recording, select , and select Record Camera Audio or Record Camera
Video.
Select Start.
Follow the on-screen
instructions and bring your vehicle to a complete stop at the starting
line.
You can start the race when Ready appears on the screen. The timer starts automatically
when the device detects rapid acceleration.
