Configuring the Antenna Ports for DAB and FM Antennas
NOTE: These instructions apply only to European models. DAB stations are broadcast only in select areas of Europe, so not all models support this feature.
There are two antenna ports on the stereo, and you can connect a DAB antenna and an FM antenna to either of them, depending on the type of connector on the antenna. After connecting an antenna, you must configure the stereo to use the antenna properly.
  1. Select Menu > SETTINGS > SOURCE > DAB.
  2. Select an option:
    • To configure an antenna port for a DAB antenna, select DAB ANTENNA.
    • To configure an antenna port fo an FM antenna, select FM ANTENNA
  3. Select the antenna port where you connected the antenna.
  4. Repeat these steps for the other antenna, if necessary.
  5. If the connected antenna requires power from the stereo, select Menu > SETTINGS > SOURCE > DAB and select ANTENNA 1 POWER or ANTENNA 2 POWER depending on which port you connected the antenna (Optional).
GUID-93B550BE-32FB-4B88-B776-F28617ABA7D5 v5
July 2026
