Specifications
General
Weight |
750 g (26.5 oz.) |
Water resistance |
IEC 60529 IPX7 (front of stereo only, when properly installed) IEC 60529 IPX2 (rear of stereo, when properly installed) |
Operating temperature range |
From 0 to 50°C (from 32 to 122°F) |
Storage temperature range |
From -20 to 70°C (from -4 to 158°F) |
Input voltage |
From 10.8 to 32 Vdc |
Current (max.) |
25 A |
Current (muted) |
Less than 900 mA |
Current (off) |
Less than 350 mA |
Fuse |
25 A mini blade-type |
NMEA 2000® LEN @ 9 Vdc |
2 (100 mA) |
Bluetooth® wireless range |
Up to 10 m (30 ft.) |
ANT® wireless range |
Up to 3 m (10 ft.) |
Wireless frequencies/protocols |
Wi‑Fi® 2.4 GHz @ +19.49 dBm maxiumum Bluetooth 2.4 GHz @ +15.11 dBm maxiumum ANT 2.4 GHz @ 3.22 dBm maxiumum |
Compass-safe distance |
40 cm (15.75 in.) |
On-board, Class D Amplifier
Output music power per channel |
4 x 80 W max. 4 ohm |
Total output peak power |
320 W |
Output power per channel 1 |
4 x 40 W RMS less than 1% THD+N, 4 ohm {CTA-2006-D} |
Line output level (max.) |
5.6 V (peak to peak) |
Aux input level (typical) |
1 V RMS typical, 2 V RMS max. |
Tuner frequencies
Tuner |
Europe and Australasia |
USA |
Japan |
FM radio frequency range |
87.5 to 108 MHz |
87.5 to 107.9 MHz |
76 to 95 MHz |
FM frequency step |
50 kHz |
200 kHz |
50 kHz |
AM radio frequency range |
522 to 1620 kHz |
530 to 1710 kHz |
522 to 1620 kHz |
AM frequency step |
9 kHz |
10 kHz |
9 kHz |
DAB frequency |
174 to 240 MHz (Band III) |
N/A |
N/A |
