Important Safety Information
WARNING
Failure to follow these warnings and cautions could result in personal injury, damage to the vessel, or poor product performance.
WARNING
See the Important Safety and Product Information guide in the product box for product warnings and other important information.
WARNING
This device must be installed according to these instructions.
WARNING
Disconnect the vessel's DC power supply before making any modifications to it.
WARNING
Before applying power to this product, make sure it has been correctly grounded according to these instructions.
WARNING
You must review and follow the applicable important power considerations when selecting the power cable and fuse or circuit breaker. Using an incorrectly-rated power cable, fuse, or circuit breaker for your installation type may cause a fire or other potential issues that could result in serious personal injury, damage to the device or the vessel, or poor product performance (Important Power Connection Information for New Installations).
WARNING
To avoid potential risk of fire, possibly resulting in serious personal injury or property damage, only replace fuses used in installation with the same type and rating.
CAUTION
To avoid possible personal injury, always wear safety goggles, ear protection, and a dust mask when drilling, cutting, or sanding.
NOTICE
When drilling or cutting, always check what is on the opposite side of the surface to avoid damaging the vessel.
NOTICE
Do not use the stereo as a template when drilling the mounting holes because this may damage the glass display and void the warranty. You must only use the included template to correctly drill the mounting holes.
NOTICE
The installer is responsible for ensuring the installation complies with all applicable local, regional, and national regulations, standards, and best practices for marine electrical systems. You must verify that all wiring, circuit protection, grounding, and installation methods comply with the requirements for the vessel and installation location, including applicable standards such as ABYC®, ISO, RCD or other relevant marine electrical standards.
You must read all installation instructions before beginning the installation. If you experience difficulty during the installation, contact Garmin® Product Support.
What's In the Box
  • Mounting gasket
  • Four 8-gauge, self-tapping screws
  • Two screw covers
  • Power and speaker wiring harness
  • Auxiliary-in, line-out, and subwoofer-out wiring harnesses
  • 2 m (6 ft.) NMEA 2000® drop cable
  • Dust cover
Tools Needed
  • Phillips screwdriver
  • Electric drill
  • Drill bit (size varies based on surface material and screws used)
  • Rotary cutting tool or jigsaw
  • Appropriately-rated circuit breaker or inline fuse for the primary power cable (Important Power Connection Information for New Installations)
  • 1 A inline fuse for the ignition cable
  • Silicone-based marine sealant (optional)
  • Wire for power and ground cable extension. The required wire gauge depends on the length of the extension and the connected power source (Power Cable Gauge Guide).
  • 22 AWG (0.33 mm2) wire for ignition cable extension
GUID-93B550BE-32FB-4B88-B776-F28617ABA7D5 v6
August 2026
