NMEA 2000 System Wiring Diagram
Stereo |
Supported chartplotter, MFD, or compatible Fusion® NMEA 2000® remote control |
NMEA 2000 GPS antenna, speed sensor, or wind instrument. When the stereo is connected to the same NMEA 2000 network as a compatible engine, a GPS antenna, a chartplotter with a built-in GPS antenna, a wind instrument, or a water speed sensor, it can be configured to automatically adjust the volume according to the engine RPM, the speed over ground, the wind speed, or the speed through water. See the stereo Owner's Manual for more information. |
In-line switch |
NMEA 2000 power cable NOTE:
A standard NMEA 2000 power cable has an inline fuse that should be installed when
making this connection.
NMEA 2000 drop cable, up to 6 m (20 ft.) |
9 to 16 Vdc power supply |
NMEA 2000 terminator or backbone cable |
NMEA 2000 T-connector |
