Turning On the Device Manually
Before you turn on the device using battery power, you should fully charge the battery.
NOTE: When the device is connected to an ignition-switched power outlet, it turns on automatically when you turn on the vehicle.
Select Power symbol .
The device turns on.
GUID-93747543-12A8-453C-9896-32070F5B0710 v1
September 2024
