Profile
Adding a Profile
You can add a .pro file that contains profile information by creating it using the Applied Ballistics Quantum™ app and transferring the file to the AB folder on the device. You can also create a profile using your Garmin® device.
  1. From the home screen, press Up arrow, and select AB MENU.
  2. Select PROFILE > PROFILE > CREATE NEW PROFILE.
Editing a Profile
  2. Select PROFILE > PROFILE.
  3. Select a profile.
  4. Select an option:
    • To enter the bullet properties, select BULLET PROPERTIES, and select an option.
      TIP: You can select BULLET DATABASE to automatically enter bullet properties from the Applied Ballistics® bullet database. If you manually enter the bullet properties, you can find the information on the bullet manufacturer's website.
    • To enter the gun and scope properties, select GUN PROPERTIES, and select an option.
    • To calibrate the muzzle velocity to provide a more accurate solution in the supersonic range for your firearm, select GUN PROPERTIES > CALIBRATE MUZZLE VELOCITY, select an option, and select DONE.
    • To calibrate the drop scale factor to provide a more accurate solution at or beyond the transonic range for your firearm, select GUN PROPERTIES > CALIBRATE DSF, select an option, and select DONE.
      NOTE: Garmin recommends you calibrate the muzzle velocity prior to calibrating the drop scale factor. After you calibrate the drop scale factor, you can select GUN PROPERTIES > VIEW DSF TABLE to view the drop scale factor table. If necessary, you can press Range button while viewing the drop scale factor table to reset it to the default values.
    • To edit the muzzle velocity temperature table, select GUN PROPERTIES > MV-TEMP TABLE, and select a value to edit.
      NOTE: If necessary, you can press Range button when no value is highlighted to reset the muzzle velocity temperature table back to the default values.
    • To edit the units of measure for output fields, select OUTPUT UNITS.
Deleting a Profile
NOTE: You cannot delete your current profile.
  4. Select DELETE PROFILE.
Selecting a Different Profile
  4. Select SELECT PROFILE.
GUID-9258AC82-CE63-4DE9-84B7-473FEB0EA745 v3
November 2026
