Adding Contacts
You can add up to 50 contacts to the Garmin Connect™ app. Contact emails can be used with the LiveTrack feature. Three of these contacts can be used as assistance contacts (Adding Assistance Contacts).
  1. From the Garmin Connect app, select Menu symbol.
  2. Select Contacts.
  3. Follow the on-screen instructions.
After you add contacts, you must sync your data to apply the changes to your Approach® S72 device (Using the Garmin Connect App).
GUID-91BDFC0A-876D-451A-AF8E-8DD63A4D6B85 v1
October 2026
