Using ClimbPro
The ClimbPro feature helps you manage your effort for the upcoming climbs on a course. You can view climb details, including gradient, distance, and elevation gain, before or in real time while following a course. Cycling climb categories, based on length and gradient, are indicated by color.
  1. From the watch face, swipe left.
  2. Select More activities symbol, and select an activity.
    NOTE: This feature is not available for all activities.
  3. Scroll down, and select the activity settings.
  4. Select ClimbPro > Status > When Navigating.
  5. Select an option:
    • Select Data Field to customize the data field that appears on the ClimbPro screen.
    • Select Alert to set alerts at the start of a climb or at a certain distance from the climb.
    • Select Descents to turn descents on or off for running activities.
    • Select Climb Detection to choose the types of climbs detected during cycling activities.
  6. Review the climbs and course details for the course.
  7. Start following a saved course (Navigating to a Destination).
GUID-91BDFC0A-876D-451A-AF8E-8DD63A4D6B85 v1
October 2026
