Satellite Settings
You can change the GNSS satellite setting to customize the accuracy and battery usage used for each activity. Each satellite mode enables SatIQ™ technology to dynamically select the satellite systems that meet your desired accuracy and battery needs.
For more information about GNSS satellite systems, go to garmin.com/aboutGPS.
From the watch face, press Top button, select More activities symbol, select an activity, scroll down and select the activity settings, and select Satellites.
NOTE: This feature is not available for all activities.
Off
Disables GNSS satellite systems for the activity.
Use Default
Enables the watch to use the default activity focus mode setting for GNSS satellites (Customizing a Default Focus Mode).
Max Accuracy
Prioritizes maximum positioning accuracy while reducing battery life. This setting provides increased performance in challenging environments for short-duration activities.
Normal
Balances average positioning accuracy and average battery life. This setting provides the best positioning accuracy while still prioritizing battery life.
Extended Battery
Balances above-average battery life and below-average positioning accuracy. This setting provides the best battery life while still prioritizing positioning accuracy.
Max Battery
Prioritizes maximum battery life while reducing positioning accuracy. This setting records track points and sensor data less frequently for long-duration activities.
GUID-91BDFC0A-876D-451A-AF8E-8DD63A4D6B85 v1
October 2026
