Viewing Transceiver Data During a Dive
  1. Press DOWN to view the data screen.
    TIP: You can customize the dive data screens to view the transceiver and diver dashboard data on dedicated data screens (Customizing the Data Screens).
    Transmitter data screen with callouts
    1
    The gas consumption estimate for your transceiver (Selecting the Gas Consumption Rate Metric).
    2
    The air time remaining (ATR) estimate for your transceiver.
    3
    Your primary and secondary transceivers and their tank pressure values.
    You can customize which transceivers are displayed (Selecting Transceivers to View During a Dive). When the sidemount setup feature is enabled, your left and right tanks appear (Enabling Sidemount Setup).
    NOTICE
    The transceiver communicates using SubWave™ sonar technology below water and ANT® technology above water. At shallow depths less than 1.2 m (4 ft.) and at the start of a dive, the NO COMMS alert may appear while the transceiver and dive computer reestablish a connection.
  2. Press START, and select Divers to view the tank pressure values, approximate depths, and approximate distances of the paired Descent™ transceivers in the network.
    Diver network data
    NOTE: Not all features are available for older devices (Dive Product and Feature Compatibility).
GUID-9183E86B-2399-4CFC-AB50-EAFC6D6ED326 v8
August 2026
