Power Cable
When connecting the power cable, do not remove the in-line fuse holder. To prevent the possibility of injury or product damage caused by fire or overheating, the appropriate fuse must be in place as indicated in the product specifications. Connecting the power cable without the appropriate fuse in place voids the product warranty.
The power cable (included) connects the device to power.
If it is necessary to extend the power and ground wires, you must use 0.82 mm2 (18 AWG) or larger wire.
NOTE:
Disregard the blue and brown wires.
Item |
Wire Function |
Wire Color |
Power |
Red |
Ground |
Black |
Not used |
Blue |
Not used |
Brown |
Parent Topic: Connection Considerations
