Changing the Units of Measure
  1. Select Apps list to open the apps list.
  2. Select Settings > System > Units.
  3. Select an option:
    • To change the unit of measure for speed and distance, select Speed/Distance.
    • To change the unit of measure for vertical speed, select Vertical Speed.
    • To change the unit of measure for elevation, select Elevation > Elevation.
    • To change the unit of measure for depth to feet, fathoms, or meters, select Elevation > Depth.
    • To change the unit of measure for temperature, select Temperature.
    • To change the unit of measure for pressure, select Pressure.
  4. Select a unit of measure.
GUID-8D90560B-85C8-4152-B6AB-6D738460D100 v5
September 2026
