Downloading Maps
Before you can download maps to your device, you must pair your device with the Garmin Explore™ app (Pairing Your Phone), and connect to a wireless network (Connecting to a Wireless Network).
  1. Select Apps list to open the apps list.
  2. Select Map Manager > Outdoor Maps+.
  3. Select Get Outdoor Maps+ to download premium maps and activate your Outdoor Maps+ subscription for this device.
    NOTE: Go to garmin.com/outdoormaps for information about purchasing a subscription.
  4. If necessary, select New Map.
  5. Select an option to select the map location:
    • Select Use Map to download an area directly from the map.
    • Select a category, such as recent finds or waypoints, and select a location.
    A preview of the map region appears.
  6. From the map, complete one or more actions:
    • Drag the map to view different areas.
    • Pinch or spread two fingers on the touchscreen to zoom in and out of the map.
    • Select Plus symbol and Minus symbol to zoom in and out of the map.
    • Double-tap the map to quickly zoom in.
  7. Select Next.
  8. Complete one or more actions:
    • To edit the map name, select Name.
    • To change the map layers to download, select the checkboxes next to each layer's name.
      NOTE: You can select Menu and select Layer Information to view details about the map layers.
    An estimated download size appears for the map. You should verify your device has enough available storage space for the map.
  9. Select Download.
GUID-8D90560B-85C8-4152-B6AB-6D738460D100 v5
September 2026
