Viewing the Elevation Plot of a Course
The elevation plot displays the elevation data for a course based on your routing settings when navigating. If routing is disabled, the elevation plot displays the straight-line elevation data between course points. If routing is enabled, the device adjusts the course to follow map data and recalculate as needed, and the elevation plot displays the elevation data along the roads included in your course.
  1. From the home page, select Saved.
  2. Select a course.
  3. Select Elevation plot.
GUID-8D90560B-85C8-4152-B6AB-6D738460D100 v5
September 2026
