Data Fields
Some data fields require you to be navigating or require wireless accessories to display data.
24 hr Max. Temp.
The maximum temperature recorded in the last 24 hours from a compatible temperature sensor.
24 hr Min. Temp.
The minimum temperature recorded in the last 24 hours from a compatible temperature sensor.
Accuracy of GPS
The margin of error for your exact location. For example, your GPS location is accurate to within +/- 3.65 m (12 ft.).
Activity Distance
The distance traveled for the current track or activity.
Activity Time
The current time of the activity timer.
Ambient Pressure
The uncalibrated ambient pressure.
Ascent - Average
The average vertical distance of ascent since the last reset.
Ascent - Maximum
The maximum rate of ascent in feet per minute or meters per minute since the last reset.
Ascent - Total
The total elevation distance ascended during the activity or since the last reset.
Automotive Turn
The direction of the next turn in the route. You must be navigating for this data to appear.
Average Cadence
Cycling. The average cadence for the current activity.
Average HR %Max.
The average percentage of maximum heart rate for the current activity.
Average Lap
The average lap time for the current activity.
Avg. HR
The average heart rate for the current activity.
Barometer
The calibrated current pressure.
Battery Level
The remaining battery power.
Bearing
The angular direction. You must be navigating for this data to appear.
Bearing to Destination
The direction from your current location to a destination. You must be navigating for this data to appear.
Cadence
Cycling. The number of revolutions of the crank arm. Your device must be connected to a cadence accessory for this data to appear.
Calories
The amount of total calories burned.
Compass Heading
The direction you are moving based on the compass.
Course
The direction from your starting location to a destination. Course can be viewed as a planned or set route. You must be navigating for this data to appear.
Current Lap
The stopwatch time for the current lap.
Date
The current day, month, and year.
Descent - Average
The average vertical distance of descent since the last reset.
Descent - Maximum
The maximum rate of descent in meters per minute or feet per minute since the last reset.
Descent - Total
The total elevation distance descended during the activity or since the last reset.
Distance to Dest.
The remaining distance to the final destination. You must be navigating for this data to appear.
Distance to Next
The remaining distance to the next waypoint on the route. You must be navigating for this data to appear.
Elapsed Activity Time
The total time recorded. For example, if you start the timer and run for 10 minutes, then stop the timer for 5 minutes, then start the timer and run for 20 minutes, your elapsed time is 35 minutes.
Elevation
The altitude of your current location above or below sea level.
Elevation Above Ground
The altitude of your current location above ground level.
Elevation - Maximum
The highest elevation reached since the last reset.
Elevation - Minimum
The lowest elevation reached since the last reset.
ETA at Destination
The estimated time of day when you will reach the final destination (adjusted to the local time of the destination). You must be navigating for this data to appear.
ETA at Next
The estimated time of day when you will reach the next waypoint on the route (adjusted to the local time of the waypoint). You must be navigating for this data to appear.
Glide Ratio
The ratio of horizontal distance traveled to the change in vertical distance.
Glide Ratio to Dest.
The glide ratio required to descend from your current position to the destination elevation. You must be navigating for this data to appear.
GPS Elevation
The altitude of your current location using GPS.
GPS Heading
The direction you are moving based on GPS.
GPS Signal Strength
The strength of the GPS satellite signal.
Grade
The calculation of rise (elevation) over run (distance). For example, if you climb 3 m (10 ft.) for every 60 m (200 ft.) you travel, the grade is 5%.
Heading
The direction you are moving.
Heart Rate
Your heart rate in beats per minute (bpm). Your device must be connected to a compatible heart rate monitor.
Heart Rate - %Max.
The percentage of maximum heart rate.
Heart Rate Zone
The performance zone of your current heart rate (1 to 5). The default zones are based on your user profile and maximum heart rate (220 minus your age).
Lap Ascent
The vertical distance of ascent for the current lap.
Lap Cadence
Cycling. The average cadence for the current lap.
Lap Descent
The vertical distance of descent for the current lap.
Lap Distance
The distance traveled for the current lap.
Lap Heart Rate Percent
The average percentage of maximum heart rate for the current lap.
Lap HR
The average heart rate for the current lap.
Laps
The number of laps completed for the current activity.
Lap Speed
The average speed for the current lap.
Last Lap Ascent
The vertical distance of ascent for the last completed lap.
Last Lap Cadence
Cycling. The average cadence for the last completed lap.
Last Lap Descent
The vertical distance of descent for the last completed lap.
Last Lap Distance
The distance traveled for the last completed lap.
Last Lap HR
The average heart rate for the last completed lap.
Last Lap Speed
The average speed for the last completed lap.
Last Lap Time
The stopwatch time for the last completed lap.
Location (lat/lon)
The current position in latitude and longitude, regardless of the selected position format setting.
Location (selected)
The current position using the selected position format setting.
Location of Dest.
The position of your final destination. You must be navigating for this data to appear.
None
This is a blank data field.
Odometer
A running tally of the distance traveled for all trips. This total does not clear when resetting the trip data.
Off Course
The distance to the left or right by which you have strayed from the original path of travel. You must be navigating for this data to appear.
Pace
The current pace.
Pointer
An arrow points in the direction of the next waypoint or turn. You must be navigating for this data to appear.
Speed
The current rate of travel.
Speed Limit
The reported speed limit for the road. Not available in all maps and in all areas. Always rely on posted road signs for actual speed limits.
Speed - Maximum
The highest speed reached since the last reset.
Speed - Moving Avg.
The average speed while moving since the last reset.
Speed - Overall Avg.
The average speed while moving and stopped since the last reset.
Stopwatch Timer
The stopwatch time for the current activity.
Sunrise
The time of sunrise based on your GPS position.
Sunrise/Sunset
The time of the next sunrise or sunset based on your GPS position.
Sunset
The time of sunset based on your GPS position.
Temperature
The temperature of the air. Your body temperature affects the temperature sensor. Your device must be connected to a tempe™ sensor for this data to appear.
Time of Day
The time of day based on your current location and time settings (format, time zone, daylight saving time).
Time to Destination
The estimated time remaining before you reach the destination. You must be navigating for this data to appear.
Time to Next
The estimated time remaining before you reach the next waypoint in the route. You must be navigating for this data to appear.
To Course
The direction in which you must move to get back on the route. You must be navigating for this data to appear.
Total Lap
The stopwatch time for all the completed laps.
Trip Odometer
A running tally of the distance traveled since the last reset.
Trip Time
A running tally of the total time spent moving and not moving since the last reset.
Trip Time - Moving
A running tally of the time spent moving since the last reset.
Trip Time - Stopped
A running tally of the time spent not moving since the last reset.
Turn
The angle of difference (in degrees) between the bearing to your destination and your current course. L means turn left. R means turn right. You must be navigating for this data to appear.
Velocity Made Good
The speed at which you are closing on a destination along a route. You must be navigating for this data to appear.
Vertical Dist. to Dest.
The elevation distance between your current position and the final destination. You must be navigating for this data to appear.
Vertical Dist. to Next
The elevation distance between your current position and the next waypoint in the route. You must be navigating for this data to appear.
Vertical Speed
The rate of ascent or descent over time.
Vertical Speed to Dest.
The rate of ascent or descent to a predetermined altitude. You must be navigating for this data to appear.
Waypoint at Dest.
The last point on the route to the destination. You must be navigating for this data to appear.
Waypoint at Next
The next point on the route. You must be navigating for this data to appear.
GUID-8D90560B-85C8-4152-B6AB-6D738460D100 v5
September 2026
