Changing the Camera View
When using a compatible camera, such as a GC™ 245/255, you can change the appearance of the camera view.
  1. From a video screen, select Options.
  2. Select Camera View and select an option:
    • For a typical camera view, select Standard.
    • For a wide-angle view with slight circular distortions, select Fish Eye.
      NOTE: Distance markers or guidance lines are not available when using the Fish Eye camera view.
    • For an overhead view of the vessel, select Bird's Eye
      NOTE: The bird's-eye view is available only if your camera was installed by your boat builder and if they properly calibrated the system. Distance markers are available when using the bird's-eye view, but guidance lines are not.
GUID-8D60E520-A4CC-4669-8D45-79C61C3778A4 v5
September 2026
