GPSMAP 9x13xsv Specifications
Specification
Measurement
Dimensions (W × H × D)
33.5 × 23.4 × 9.1 cm (13.20 × 9.19 × 3.56 in.)
Display size (W × H × diagonal)
29.4 × 16.5 × 33.7 cm (11.57 × 6.50 × 13.27 in.)
Weight
4.13 kg (9.1 lb.)
Display resolution
4KUHD, 3840 × 2160 pixels
Max. power usage
63 W
Typical current draw at 12 Vdc
4.7 A
Typical current draw at 24 Vdc
2.5 A
Compass-safe distance
55 cm (22 in.)
Material
Polycarbonate plastic and die-cast aluminum
Water rating
IEC 60529 IPX71
Temperature range
From -15° to 55°C (from 5° to 131°F)
Input voltage
From 10 to 32 Vdc
Fuse
10 A
NMEA 2000® LEN @ 9 Vdc
2
NMEA 2000 Draw
70 mA max.
Wireless frequencies and transmit power
2.4 GHz: < 20 dBm
5 150-5 250 MHz: < 23 dBm
5 250-5 850 MHz: < 20 dBm
HTML integration
Compatible with OneHelm™ integration
Max. waypoints
5,000
Max. routes
100
Max. active track points
50,000 points, 50 saved tracks
1 The device withstands incidental exposure to water of up to 1 m for up to 30 min. For more information, go to www.garmin.com/waterrating.
GUID-8D60E520-A4CC-4669-8D45-79C61C3778A4 v5
September 2026
