Following an Orbit Pattern
You can use the orbit pattern to steer the boat in a continuous circle around the active waypoint. The size of the circle is defined by your distance from the active waypoint when you begin the orbit pattern.
  1. From the autopilot screen, select Options > Pattern Steering > Orbit.
  2. Select Engage Port or Engage Starboard.
GUID-8D60E520-A4CC-4669-8D45-79C61C3778A4 v5
September 2026
