Touchscreen Controls for a Connected Computer (GPSMAP 9x10xsv/9x13xsv/9x17xsv/9x19/9x22/9x24/9x27)
NOTICE
To prevent corrosion due to moisture, you must use Garmin® GPSMAP® accessory cables when connecting the chartplotter to the computer. Using different cables voids your warranty.
You can connect the chartplotter to a computer to see the computer screen on the chartplotter touchscreen and control the computer using the chartplotter touchscreen. To see the computer screen, you must connect the computer to the HDMI IN port. To control the computer, you must connect the computer to the USB DRD port.
The Garmin HDMI® accessory cable (010-12390-20) is 4.5 m (15 ft) long. If you need a longer cable, you should use an active HDMI cable only. You need an HDMI coupler to connect the two HDMI cables.
The recommended Garmin USB Cable (010-12390-14) is 4.5 m (15 ft) long. If you need a longer cable, you should use a USB hub or USB repeater extension cable only.
NOTICE
To avoid potential communication errors, you should use the correct USB cable for your chartplotter. You should not use an adapter to change the USB connector type on an older cable.
You must make all cable connections in a dry environment.
Block diagram
Devices
Item
Device
1
Computer
2
GPSMAP chartplotter
Connections
From
To
Cable
1
Computer's HDMI OUT port
2
Chartplotter's HDMI IN port
Garmin HDMI Cable (010-12390-20)
3
Chartplotter's USB DRD port
4
Computer's USB port
Garmin USB-C to USB-A Cable (010-12390-14)
GUID-8D60E520-A4CC-4669-8D45-79C61C3778A4 v5
September 2026
