GPSMAP 9x10xsv Specifications
Specification
Measurement
Dimensions (W × H × D)
26 × 20 × 9.1 cm (10.24 × 7.87 × 3.54 in.)
Display size (W × H × diagonal)
21.7 × 13.6 × 25.6 cm (8.54 × 5.34 × 10.1 in.)
Weight
2.52 kg (5.55 lb.)
Display resolution
WUXGA, 1920 × 1200 pixels
Max. power usage
45.1 W
Typical current draw at 12 Vdc
3.6 A
Typical current draw at 24 Vdc
1.8 A
Compass-safe distance
40 cm (16 in.)
Material
Polycarbonate plastic and die-cast aluminum
Water rating
IEC 60529 IPX71
Temperature range
From -15° to 55°C (from 5° to 131°F)
Input voltage
From 10 to 32 Vdc
Fuse
10 A
NMEA 2000® LEN @ 9 Vdc
2
NMEA 2000 Draw
70 mA max.
Wireless frequencies and transmit power
2.4 GHz: < 20 dBm
5 150-5 250 MHz: < 23 dBm
5 250-5 850 MHz: < 20 dBm
HTML integration
Compatible with OneHelm™ integration
Max. waypoints
5,000
Max. routes
100
Max. active track points
50,000 points, 50 saved tracks
1 The device withstands incidental exposure to water of up to 1 m for up to 30 min. For more information, go to www.garmin.com/waterrating.
GUID-8D60E520-A4CC-4669-8D45-79C61C3778A4 v5
September 2026
