Surface Pressure and Water Temperature Data
Surface-pressure information appears as pressure isobars and pressure centers. Isobars connect points of equal pressure. Pressure readings can help to determine weather and wind conditions. High-pressure areas are generally associated with fair weather. Low-pressure areas are generally associated with clouds and the chance of precipitation. Isobars packed closely together show a strong pressure gradient. Strong pressure gradients are associated with areas of stronger winds.
Pressure units are shown in millibars (mb), inches of Mercury (inHg), or hectopascals (hPa).
Colored shading indicates the surface temperature of the water, as shown in the legend in the corner of the display.
GUID-8D60E520-A4CC-4669-8D45-79C61C3778A4 v5
September 2026
