Playing Golf
Before you play golf for the first time, you must download the Garmin Golf™ app from the app store on your phone (Garmin Golf App).
Before you play golf, you should charge the watch (Charging the Watch).
  1. From the watch face, swipe left.
  2. Select Activities > Outdoor > Golf.
    The device locates satellites, calculates your location, and selects a course if there is only one course nearby.
  3. If the course list appears, select a course from the list.
    Courses are updated automatically.
  4. Select Checkmark symbol to keep score.
  5. Select a tee box.
    The hole information screen appears.
    Golf hole data with callouts
    1
    Current hole number
    2
    Distance to the back of the green
    3
    Distance to the middle of the green
    4
    Distance to the front of the green
    5
    Par for the hole
    6
    Map of the green
    NOTE: Because pin locations change, the watch calculates the distance to the front, middle, and back of the green, but not the actual pin location.
  6. Select an option:
    • Tap the map to view more detail or change the pin location (Moving the Flag).
    • Press Line drawing of the watch with a top button callout to open the golf menu (Golf Menu).
When you move to the next hole, the watch automatically transitions to display the new hole information.
GUID-8C2C402F-55AC-431F-9CF2-1442B89CE149 v7
September 2026
