Viewing the Live View Camera Feed
Before you can view the Live View camera feed remotely, you must have an active Vault subscription and you must connect your camera to a Wi‑Fi® network (Connecting Your Camera to a Wi‑Fi Network).
You can also connect your camera to a constant 12V power source (Constant Power Cable).
You can view the live camera feed using the Live View feature in the Garmin Drive™ app. You can connect directly to your paired camera using Bluetooth® technology, or you can connect remotely using a Wi‑Fi network.
  1. From the Garmin Drive app on your smartphone, select Live View.
    The app scans for available cameras.
  2. If necessary, select your camera from the list of available devices.
    The live view appears.
GUID-8B5CEA4F-A508-4496-9EDE-B6D1669C09BE v2
March 2025
