Installing the Device
  1. Set the time switch (Time Switch).
  2. Connect the device to the OBD II port in your vehicle.
    The OBD II port is usually located under the dashboard on the driver's side of the vehicle. The OBD II port location may vary depending on the make and model of your vehicle. See your vehicle owner's manual for more information.
  3. Remove the protective film from one reclosable fastener, and press the reclosable fastener firmly onto the USB port end of the device for 10 seconds.
  4. Clean the vehicle mounting surface using water or alcohol, and a lint-free cloth.
  5. Allow the surface to dry completely.
  6. Remove the protective film from a second reclosable fastener, and press it firmly onto the vehicle mounting surface for 10 seconds.
  7. Press the reclosable fastener on the device against the reclosable fastener on the mounting surface to secure the device to the mounting location.
  8. Connect the USB power cable from your Garmin Dash Cam™ device to a USB port on the Constant Power Cable device.
GUID-8B5CEA4F-A508-4496-9EDE-B6D1669C09BE v2
March 2025
