Updating Your Device Using the Garmin Drive App
The Garmin Drive™ app notifies you when a software update is available for your device. You can also check for updates at any time.
  1. From the Garmin Drive app, select your camera.
  2. Select Settings > Check for Updates.
  3. Select Install Now.
    The software update is sent to your device. You are notified when the transfer is complete.
  4. Disconnect the device from power until the device turns off.
  5. Connect the device to power.
    The device installs the software update.
    NOTE: Video is not recorded while the software is updating.
GUID-8B5CEA4F-A508-4496-9EDE-B6D1669C09BE v2
March 2025
