Voice Control
The voice control feature allows you to control your camera by saying words and commands.
NOTE: The voice control feature is not available for all languages. You can use this feature while the interface is set to an unsupported language, but you must speak the commands in English.
Controlling the Camera Using Voice Commands
  1. Say OK, Garmin to activate the voice control feature.
    The camera plays a tone and starts listening for a command.
  2. Say a command:
    • To save a video, say Save Video.
    • To enable audio recording for your videos, say Record Audio.
    • To disable audio recording for your videos, say Stop Audio.
    The camera plays a tone when it recognizes your command.
Turning Voice Control On or Off
You can turn voice control on or off from the Garmin Drive™ app on your smartphone.
From the device settings menu, select Voice Commands, and select an option.
Changing the Wake Word
By default, your dash camera's voice control activates when you say OK, Garmin. You can change the wake word from the Garmin Drive app on your smartphone.
From the device settings menu, select Wake Word, and select a wake word.
Voice Control Tips
  • Speak in a normal voice directed at the device.
  • Reduce background noise to increase the accuracy of the voice recognition.
  • Before each command, say the wake word. The default wake word is OK, Garmin.
  • Listen for a tone to confirm that the camera successfully recognized a command.
  • Change the wake word if you have more than one Garmin® device with voice control features (Changing the Wake Word).
GUID-8B5CEA4F-A508-4496-9EDE-B6D1669C09BE v2
March 2025
