Connecting the Parking Mode Cable Accessory to Power
CAUTION
Garmin® strongly recommends having an experienced installer with the proper knowledge of electrical systems install the device. Incorrectly wiring the power cable can result in damage to the vehicle or the battery and can cause bodily injury.
  1. Route the parking mode cable accessory to a location in the vehicle with constant power, switched power, and a ground connection.
  2. Connect the BATT wire to a constant power source.
  3. Connect the ACC wire to a switched power source.
  4. Connect the GND wire to the bare metal of the vehicle's chassis using an existing bolt or screw.
  5. Plug the parking mode cable accessory into the USB port on the camera.
GUID-8B5CEA4F-A508-4496-9EDE-B6D1669C09BE v2
March 2025
