Cycling Posture
NOTE:
Cycling posture is unique to each cyclist and may require several adjustments. Pedals and tablets are not included with the
Tacx® NEO Bike Plus trainer and can impact your cycling posture.
The image contains guidelines for the correct cycling posture while using the Tacx NEO Bike Plus trainer.
Your elbows should be slightly bent, and you should be able to reach the shifters and brakes comfortably. At the bottom of the pedal stroke, your knee should be slightly bent.
Parent Topic: Before Assembly
