LED Fuse Installation
You must install an inline fast-blow fuse on the positive wire at the power-source end of the LED cable for each speaker to protect the LEDs and the speaker from excessive electrical current. Failure to install a fuse could cause a fire resulting in property damage, serious personal injury, or death.
The fuse must be installed in a fuse holder intended for marine use.
The fuse must be installed on the positive wire on the power-source end of the LED cable.
The fuse must be installed for use with any power source, including a lighting controller.
Always use a fuse of the correct amperage rating and type for your speaker model.
Model |
Fuse Amperage |
M6-8IB |
750 mA |
Parent Topic: LED Wiring
