Connecting Vehicle and Backup Cameras
You can connect up to four analog vehicle cameras to the infotainment system for backup, left, right, and front cameras.
For each camera, route the camera's RCA analog video cable to the back of the stereo.
You should clearly label each cable for reference when you are connecting them to the stereo.
For each camera, determine the analog high signal that should trigger the stereo to display the camera, and route a wire for that signal to the back of the stereo.
For example, you can use a reverse signal to trigger the backup camera when the vehicle is put in reverse, or you can use turn signal to trigger a side mirror camera.
Connect each RCA analog video cable to the
VIDEO IN connectors on the back of the stereo, as shown.
Front camera
Left camera
Right camera
Backup camera
- Connect the analog high signal wire for the backup camera to the pink REVERSE wire of the power and speaker wiring harness (Power and Speaker Wiring Harness).
Connect the analog high signal wire for each of the other cameras to the appropriate camera detect wire of the analog signal detect harness (Analog Signal Detect Wiring Harness).
NOTE: If you do not want to trigger a camera automatically, you should leave that camera detect wire disconnected.
Harness wire color
Camera
Blue
Left camera
Orange
Right camera
Brown
Front camera
Parent Topic: Connector Identification
