Mounting the GOS 10 Hub
Before you can mount the device, you must select a location in accordance with the mounting considerations.
- Hold the device on the mounting surface, and mark the locations for the pilot holes.
Remove the device from the mounting surface.
NOTICE
Do not drill through the GOS™ 10 hub when drilling the mounting holes because this may damage the device and void the warranty.
- Using a 2 mm (5/64 in.) drill bit, drill the pilot holes.
- Ensure the mounting holes on the device line up with the pilot holes.
Fasten the included screws into the pilot holes, leaving room to attach the device.
NOTICE
Do not apply grease or lubricant to the screws when fastening the device to the mounting surface. Grease or other lubricants can cause damage to the device housing.
- Place the device over the screw heads, and slide the device downward to lock it into place.
Secure the device to the mounting surface by tightening the four screws until they are snug.
NOTICE
Do not overtighten the screws. This may crack the housing.
